SCU wake event not working
Lakshmi_AG
We are trying to wake up AP cores from sleep mode using SCU wake event,
Using below SCU configuration before executing WFE.
sc_irq_enable(ipc_handle, 297U, SC_IRQ_GROUP_WAKE, SC_IRQ_PAD, SC_TRUE);
    /* Enable GPIO pad wakeup */
    sc_pad_set_wakeup(ipc_handle, 40U, 6U);//SC_PAD_WAKEUP_RISE_EDGE 6U
    sc_pm_req_low_power_mode(ipc_handle, SC_R_A53, SC_PM_PW_MODE_OFF);
    sc_pm_req_cpu_low_power_mode(ipc_handle, SC_R_A53, SC_PM_PW_MODE_OFF, SC_PM_WAKE_SRC_SCU);
But SCU is not generating interrupt to resume the core out of WFE.
Zhiming_Liu
Do you have ATF layer in your project?
Lakshmi_AG
No, We are trying to follow same steps as mentioned in ATF but executing in bare metal env.
