Problem in getting hardware acceleration for open gles - gpu sdk samples with fbdev
1,764件の閲覧回数
sudiptasubudhi
I am compiling the samples using framebuffer libraries(fbdev) on a imx6q device.Modules like drm.ko,vivante.ko,galcore.ko are present. Libraries like vivante_dri.so in /usr/lib/dri and vivante_drv.so in /usr/lib/xorg/modules/drivers are also present. I have installed gpu-viv-bin-mx6q-3.10.17-1.0.0.
But,when i run the samples, they are not hardware accelerated.
How can i achieve this?
Thanks in advance,
Sudlin
ラベル(3)
1,540件の閲覧回数
Bio_TICFSL
Hi Sudlin,
Please check Ubuntu X window will hang with i.MX 6 Q/D L3.0.35_1.1.0 GA release general information on the procedure to get hardware acceleration to work.
