Power Calculation excel sheet for i.MX 6 Solo Processor
subham_p
Dear Sir/Ma'am
For i.MX6 Solo Processor where I will get Power Calculation excel sheet so that I can check how much power actual the device will consume when 1 Video input and 2 Video Output and Keypad interface is working at same time. Can you please help me to find out Power Calculation excel sheet or any file where I can enable or disable all interface to see the total power consumption by i.MX6 Solo Processor. Waiting for your replay asap.
Thank You & Regards
Subham Pradhan
gusarambula
Hello Subham Pradhan,
There is not an Excel calculator for the i.MX6 Solo. There is an Application Note that can serve as reference with a couple of actual scenarios. Application Note 4715 (link below)
https://www.nxp.com/docs/en/application-note/AN4715.pdf
I hope this helps!
