PEx for i.MX6: Eclipse plug-in installer?
已解决
跳至解决方案
1,627 次查看
norishinozaki
Contributor V
I'd like to use Processor Expert for i.MX6 VRE.1.0.1 by using Eclipse plug-in installer.
I'm reading the "Installation User's Guide(PEXIMXINSUG.pdf)"
Where can I download PEx_for_i.MX_<version>_Eclipse_Plugin_Installer_UnzipMe.zip ?
Nori Shinozaki
标签 (1)
1 解答
1,375 次查看
Yuri
The link is availabe now.
Yuri.
在原帖中查看解决方案
7 回复数
1,375 次查看
Yuri
1,375 次查看
norishinozaki
Contributor V
Hello Yuri,
Thanks but it's a full Eclipse installer for Windows.
I'm looking for a plugin addition for an already installed Eclipse environment.
That name must be" PEx_for_i.MX_<version>_Eclipse_Plugin_Installer_UnzipMe.zip" as written in the
Nori Shinozaki
1,375 次查看
Yuri
  I located the package in attachments of the following thread
Integrating Processor Expert for i.MX and ARM GCC with Eclipse
Yuri
1,375 次查看
norishinozaki
Contributor V
Hello Yuri,
I looked at the thread to find out two attachments,
sources.7z.zip and sd_image.7z.zip.
Non of them are the plug-in mentioned in the document.
Did you forget to attach it?
Nori Shinozaki
1,376 次查看
Yuri
Yuri.
1,375 次查看
norishinozaki
Contributor V
Yuri,
I could get that.
Thanks for the instruction as well.
Nori Shinozaki
1,375 次查看
Yuri
Some pause may be because of moderation. Please try the link later.
Yuri.
