OTA-requestor-app issue on NXP i.MX8MM
yinliangren
I met the following problems when I was working on the project matter with NXP i.MX8MM board.
Current state
1.    I ran OTA-requestor-app on the YOCTO system to upgrade the thermostat-app.  44,384 packets were received and used for more than three hours.
2.   After I used gzip compression, I used OTA-requestor-app to upgrade   the thermostat-app  .16,319 packets. 36 minutes.
3 . The upgrade files received by the preceding two methods can run properly.
Present problems :
1.  How to solve the problem of long OTA upgrade time
2.  I changed the thermostat-app  software version number(/connectedhomeip/src/include/platform/CHIPDeviceConfig.h)
2.  I run the thermostat-app  at YOCTO.What Can I do if the OAT upgrade command fails to be executed?The information is as follows:
Execute a command:
sudo ./connectedhomeip/out/standalone/chip-tool  otasoftwareupdaterequestor announce-otaprovider 5678 0 0 0 8888  0
Receive the message:
[1712041578.206873][3710:3712] CHIP:IN: (S) Sending msg 237563467 on secure session with LSID: 3224
[1712041578.207262][3710:3712] CHIP:EM: Flushed pending ack for MessageCounter:244084226 on exchange 9381i
[1712041578.208019][3710:3710] CHIP:CTL: Shutting down the commissioner
[1712041578.208160][3710:3710] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1712041578.208589][3710:3710] CHIP:CTL: Shutting down the controller
[1712041578.208675][3710:3710] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1712041578.208858][3710:3710] CHIP:IN: SecureSession[0xffff7800b4f0]: MarkForEviction Type:2 LSID:3224
[1712041578.208938][3710:3710] CHIP:SC: SecureSession[0xffff7800b4f0]: Moving from state 'kActive' --> 'kPendingEviction'
[1712041578.209014][3710:3710] CHIP:IN: SecureSession[0xffff7800b4f0]: Released - Type:2 LSID:3224
[1712041578.209091][3710:3710] CHIP:FP: Forgetting fabric 0x1
[1712041578.209197][3710:3710] CHIP:TS: Pending Last Known Good Time: 2023-05-08T17:09:28
[1712041578.209704][3710:3710] CHIP:TS: Previous Last Known Good Time: 2023-05-08T17:09:28
[1712041578.209785][3710:3710] CHIP:TS: Reverted Last Known Good Time to previous value
[1712041578.209950][3710:3710] CHIP:CTL: Shutting down the commissioner
[1712041578.210023][3710:3710] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1712041578.210487][3710:3710] CHIP:CTL: Shutting down the controller
[1712041578.210566][3710:3710] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1712041578.212047][3710:3710] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1712041578.212442][3710:3710] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1712041578.212578][3710:3710] CHIP:FP: Shutting down FabricTable
[1712041578.212673][3710:3710] CHIP:TS: Pending Last Known Good Time: 2023-05-08T17:09:28
[1712041578.213232][3710:3710] CHIP:TS: Previous Last Known Good Time: 2023-05-08T17:09:28
[1712041578.213311][3710:3710] CHIP:TS: Reverted Last Known Good Time to previous value
[1712041578.214035][3710:3710] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-CEwe0s)
[1712041578.216682][3710:3710] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1712041578.217104][3710:3710] CHIP:DL: NVS set: chip-counters/total-operational-hours = 1 (0x1)
[1712041578.217189][3710:3710] CHIP:DL: Inet Layer shutdown
[1712041578.217262][3710:3710] CHIP:DL: BLE shutdown
[1712041578.217336][3710:3710] CHIP:DL: System Layer shutdown
[1712041578.218125][3710:3710] CHIP:TOO: Run command failure: IM Error 0x00000581: General error: 0x81 (UNSUPPORTED_COMMAND)
Bio_TICFSL
Make sure you are using the CHIP thermostat example for the MX8MM, the matter examples will be upgraded but so far is the only examples it provides.
Bio_TICFSL
yinliangren
Got it. Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-1841956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOTA-requestor-app%20issue%20on%20NXP%20i.MX8MM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20met%20the%20following%20problems%20when%20I%20was%20working%20on%20the%20project%20matter%20with%20NXP%20i.MX8MM%20board.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECurrent%20state%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%20ran%20OTA-requestor-app%20on%20the%20YOCTO%20system%20to%20upgrade%20the%20thermostat-app.%26nbsp%3B%2044%2C384%20packets%20were%20received%20and%20used%20for%20more%20than%20three%20hours.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%26nbsp%3B%26nbsp%3B%20After%20I%20used%20gzip%20compression%2C%20I%20used%20OTA-requestor-app%20to%20upgrade%26nbsp%3B%26nbsp%3B%20the%20thermostat-app%26nbsp%3B%20.16%2C319%20packets.%2036%20minutes.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3%20.%20The%20upgrade%20files%20received%20by%20the%20preceding%20two%20methods%20can%20run%20properly.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPresent%20problems%20%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1.%26nbsp%3B%20How%20to%20solve%20the%20problem%20of%20long%20OTA%20upgrade%20time%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%26nbsp%3B%20I%20changed%20the%20thermostat-app%26nbsp%3B%20software%20version%20number(%2Fconnectedhomeip%2Fsrc%2Finclude%2Fplatform%2FCHIPDeviceConfig.h)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%26nbsp%3B%20I%20run%20the%20thermostat-app%26nbsp%3B%20at%20YOCTO.What%20Can%20I%20do%20if%20the%20OAT%20upgrade%20command%20fails%20to%20be%20executed%3FThe%20information%20is%20as%20follows%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EExecute%20a%20command%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Esudo%20.%2Fconnectedhomeip%2Fout%2Fstandalone%2Fchip-tool%26nbsp%3B%20otasoftwareupdaterequestor%20announce-otaprovider%205678%200%200%200%208888%26nbsp%3B%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EReceive%20the%20message%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.206873%5D%5B3710%3A3712%5D%20CHIP%3AIN%3A%20(S)%20Sending%20msg%20237563467%20on%20secure%20session%20with%20LSID%3A%203224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.207262%5D%5B3710%3A3712%5D%20CHIP%3AEM%3A%20Flushed%20pending%20ack%20for%20MessageCounter%3A244084226%20on%20exchange%209381i%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208019%5D%5B3710%3A3710%5D%20CHIP%3ACTL%3A%20Shutting%20down%20the%20commissioner%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208160%5D%5B3710%3A3710%5D%20CHIP%3ACTL%3A%20Stopping%20commissioning%20discovery%20over%20DNS-SD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208589%5D%5B3710%3A3710%5D%20CHIP%3ACTL%3A%20Shutting%20down%20the%20controller%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208675%5D%5B3710%3A3710%5D%20CHIP%3AIN%3A%20Expiring%20all%20sessions%20for%20fabric%200x1!!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208858%5D%5B3710%3A3710%5D%20CHIP%3AIN%3A%20SecureSession%5B0xffff7800b4f0%5D%3A%20MarkForEviction%20Type%3A2%20LSID%3A3224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208938%5D%5B3710%3A3710%5D%20CHIP%3ASC%3A%20SecureSession%5B0xffff7800b4f0%5D%3A%20Moving%20from%20state%20'kActive'%20--%26gt%3B%20'kPendingEviction'%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209014%5D%5B3710%3A3710%5D%20CHIP%3AIN%3A%20SecureSession%5B0xffff7800b4f0%5D%3A%20Released%20-%20Type%3A2%20LSID%3A3224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209091%5D%5B3710%3A3710%5D%20CHIP%3AFP%3A%20Forgetting%20fabric%200x1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209197%5D%5B3710%3A3710%5D%20CHIP%3ATS%3A%20Pending%20Last%20Known%20Good%20Time%3A%202023-05-08T17%3A09%3A28%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209704%5D%5B3710%3A3710%5D%20CHIP%3ATS%3A%20Previous%20Last%20Known%20Good%20Time%3A%202023-05-08T17%3A09%3A28%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209785%5D%5B3710%3A3710%5D%20CHIP%3ATS%3A%20Reverted%20Last%20Known%20Good%20Time%20to%20previous%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209950%5D%5B3710%3A3710%5D%20CHIP%3ACTL%3A%20Shutting%20down%20the%20commissioner%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.210023%5D%5B3710%3A3710%5D%20CHIP%3ACTL%3A%20Stopping%20commissioning%20discovery%20over%20DNS-SD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.210487%5D%5B3710%3A3710%5D%20CHIP%3ACTL%3A%20Shutting%20down%20the%20controller%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.210566%5D%5B3710%3A3710%5D%20CHIP%3ACTL%3A%20Shutting%20down%20the%20System%20State%2C%20this%20will%20teardown%20the%20CHIP%20Stack%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.212047%5D%5B3710%3A3710%5D%20CHIP%3ADMG%3A%20All%20ReadHandler-s%20are%20clean%2C%20clear%20GlobalDirtySet%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.212442%5D%5B3710%3A3710%5D%20CHIP%3ABLE%3A%20BleConnectionDelegate%3A%3ACancelConnection%20is%20not%20implemented.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.212578%5D%5B3710%3A3710%5D%20CHIP%3AFP%3A%20Shutting%20down%20FabricTable%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.212673%5D%5B3710%3A3710%5D%20CHIP%3ATS%3A%20Pending%20Last%20Known%20Good%20Time%3A%202023-05-08T17%3A09%3A28%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.213232%5D%5B3710%3A3710%5D%20CHIP%3ATS%3A%20Previous%20Last%20Known%20Good%20Time%3A%202023-05-08T17%3A09%3A28%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.213311%5D%5B3710%3A3710%5D%20CHIP%3ATS%3A%20Reverted%20Last%20Known%20Good%20Time%20to%20previous%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.214035%5D%5B3710%3A3710%5D%20CHIP%3ADL%3A%20writing%20settings%20to%20file%20(%2Ftmp%2Fchip_counters.ini-CEwe0s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.216682%5D%5B3710%3A3710%5D%20CHIP%3ADL%3A%20renamed%20tmp%20file%20to%20file%20(%2Ftmp%2Fchip_counters.ini)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217104%5D%5B3710%3A3710%5D%20CHIP%3ADL%3A%20NVS%20set%3A%20chip-counters%2Ftotal-operational-hours%20%3D%201%20(0x1)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217189%5D%5B3710%3A3710%5D%20CHIP%3ADL%3A%20Inet%20Layer%20shutdown%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217262%5D%5B3710%3A3710%5D%20CHIP%3ADL%3A%20BLE%20shutdown%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217336%5D%5B3710%3A3710%5D%20CHIP%3ADL%3A%20System%20Layer%20shutdown%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.218125%5D%5B3710%3A3710%5D%20CHIP%3ATOO%3A%20Run%20command%20failure%3A%20IM%20Error%200x00000581%3A%20General%20error%3A%200x81%20(UNSUPPORTED_COMMAND)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1841956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20OTA-requestor-app%20issue%20on%20NXP%20i.MX8MM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGot%20it.%20Thanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20OTA-requestor-app%20issue%20on%20NXP%20i.MX8MM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EMake%20sure%20you%20are%20using%20the%20CHIP%20thermostat%20example%20for%20the%20MX8MM%2C%20the%20matter%20examples%20will%20be%20upgraded%20but%20so%20far%20is%20the%20only%20examples%20it%20provides.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
