I'm using the Yocto Freescale core-image-base on the SABRE i.MX6 QUAD evaluation board.
I'd like to use message queues but they don't seem to be supported in this kernel? Is that true or am I missing something?
THANKS IN ADVANCE
Hello Janet Estabridis,
If you are referring to POSIX message queues these are not enabled by default, but you may use menuconfig to enable this function under General Setup > POSIX Message Queues.
There is more information on how to configure the kernel on the following document, which I'm sure will be very helpful.
https://community.nxp.com/docs/DOC-94196
When I click on the link it says
My apologies. Try this link instead:
