I tried to boot the OS from SD, and the SW2 setting is 00100000.
The boot mode (SW3 setting) is 10.
The OS is booting but the system seems stick at following steps and I never get the a prompt to type a command:
Starting Xserver
Starting system message bus: dbus.
Starting Connection Manager
Starting Dropbear SSH server: dropbear.
How do I fix the issue?
Hi Albert,
Your i.MX7 is booting, you just need to connect the Ethernet or program your sdcard again.
