M4 MCU wake-up signal would be sent to the AP through the GPIO
1,308 次查看
vinothkumars
Senior Contributor IV
Hi All,
Will you please tell me the configuration for Application Processor wake up using GPIO from M4 MCU. I am working on IMX8QM-MEK board with SDK_MEK-MIMX8QM sdk.
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
5 回复数
1,146 次查看
igorpadykov
Hi Vinoth
probably "GPIO from M4 MCU" means "Rapid General-Purpose Input and Output (RGPIO)"
module of Cortex-M4 Subsystem, however this gpio module has not interrupt feature.
So seems this is not possible.
1,146 次查看
vinothkumars
Thank you Igor for the reply.
Will you please tell is it possible to configure FLEX CAN as a wakeup source to wake AP from M4 MCU
VinothS,
Vinothkumar Sekar
1,146 次查看
igorpadykov
Hi Vinoth
could you clarify, who would wake AP: FLEX CAN or M4.
1,146 次查看
vinothkumars
Hi Igor,
I know there is RPMSG  Wake-Up will be there. But, I don't know how to established this RPMSG Wake-Up in Android 9 Automotive.
Vinoth S,
Vinothkumar Sekar
1,146 次查看
vinothkumars
Hi Igor,
I needs to use FLEX CAN (currently flexcan run on M4 Core0) to wakeup the AP.
VinothS
Vinothkumar Sekar
