Please suggest whether two 2 RT1024 devices can be debugged using one JTAG connector using daisy chain connections. Is there any issues in debugging using this daisy chain connection in MCUExpresso IDE.
Hello, my name is Pavel, and I will be supporting your case, I reviewed the documentation MCUX user guide but does not mention any about this, do you have an external debugger or how do you want to do this? I found the next documentation on Seeger with J-Link.
Manual setup of JTAG chain - SEGGER Wiki
Pavel
