Hi.
I'm using yocto to build my system to run on imx8mm.
I updated the u-boot environment and managed to see my new env when I'm running bitbake fsl-image-qt5
But when I'm trying to make run the var-create-yocto-sdcard.sh script inorder to flash the image to the emmc I'm seeing the old uboot env.
Hi @Barak1234!
The image that are you compiling is not supported by NXP.
I recommend checking the Yocto Project Users Guide in the chapter "5.2 Choosing an i.MX Yocto project image".
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
Best Regards!
Chavira
