Hello, I apologize for the late reply.
I found the reason for a huge binary file size.
When placing a section into memory, if the segment is divided between two memory regions, then while creating a .bin file, the memory region in between the 2 regions will also be considered. Hence results in huge file size.
For example,
If I place const SECTIONA at 0x2000 to 0x4000
place const SECTIONB at 0x8000 to 0xF000
Then when creating the binary file,
For segment const, the memory region considered would be (0xF000 - 0x2000). The gaps between would be filled with 0s. Hence results in a huge file size.
Hope this becomes helpful to someone in furture.
Thank you.
To provide the fastest possible support, I was wondering if you can introduce the steps for replicating the phenomenon.
TIC
For example,
Thank you.
