Bring up can0 automatically on i.MX8MP
1,641 次查看
embdev1
can0 interface is down by default. How to automatically make it active after boot?
(Don't want to manually bring it UP by using IP link command in terminal)
2 回复数
1,619 次查看
jamesbone
You can enable it in the init config like the one available for the Ethernet port.
https://www.systutorials.com/docs/linux/man/5-init/
1,551 次查看
embdev1
Hi jamesbone,
Thanks for your response. Can you please tell me where can I find the code related to init config of ethernet port?
