How long should I wait for the linux-imx-5.15.5 do_fetch step?
1,645 次查看
yeongungson
yocto_build.pngI purchased imx6q board, and I am building development environment for the first time.
Also, I have no experience with Linux applications.
If you look at the attached image, it only increases the time, and there is no error. Should I just wait?
What should I do in this case?
Can anyone give me as much detail as possible?
标签 (1)
1 回复
1,600 次查看
Harvey021
Hi @yeongungson
Based on the screenshot, which shows tasks for do_fetch broken. Mostly it's caused by network slowness. I would recommend you to start over image build.
If you still have this problem after re-running. Please share your build platform and the full steps you have taken for this building.
Harvey
