On the iMX 8 QuadMax MEK (MCIMX8QM-CPU), there is a M.2 slot (key E) to connect Wifi/bluetooth modules.
I would like to use this connector to link the iMX8 to another CPU via PCIe.
Is there enough space on the left of the M.2 slot to insert an A+E keyed M.2 board ?
For instance : M.2-A+E-to-Mini-PCI-Adapter-Cable
Thank you,
Hello Jishin42,
Due to its placement on the board and the form of the module you wish to use I would think it should fit but I cannot be certain. You can see the front and back of the board on the Getting Started on the link below:
Get Started with the i.MX 8QuadMax MEK | NXP
I hope this helps!
