I.MX7 power sequencing
1,019 次查看
NIKHITHAANTONY
In the datasheet of I.MX7 it is given that, VDD_SOC should powerup before NVCC_DRAM and NVCC_DRAM_CKE. So whether it can be done by software. In hardware design, whether we need to take care anything for delaying NVCC_DRAM and NVCC_DRAM_CKE
5 回复数
1,001 次查看
NIKHITHAANTONY
Then How VDD_SOC will become high before NVCC_DRAM and NVCC_DRAM_CKE.
995 次查看
igorpadykov
in hardware. Use appropriate PMIC with power-up sequence compatible with i.MX7D datasheet
requirements.
987 次查看
NIKHITHAANTONY
We designed I.MX7 processor as per SABRE board. In that PMIC PF3000 is used.
So there will be correct power sequencing..right?
982 次查看
igorpadykov
right
1,007 次查看
igorpadykov
Hi NIKHITHA
>whether it can be done by software..
no
no need.
