How to use LVDS output
1,318 次查看
ko-hey
Senior Contributor II
Hi all
I have question about using LVDS output.
1.When I use LVDS output, do I need any register settings of IPU ?
  If yes, please let me know the register.
2.I'm watching both a figure37-39 and figure39-1.
  In my understanding, DI's output is connected to LDB input such as lcdif1_data, lcdif1_hsync, lcdif1_vsync, lcdif1_enable, lcdif1_reset and lcdif1_clk.
  If my understanding is correct, please tell me knoe the connection of each port.
3.Does LVDS_TXx and LVDS_CLK are made from Parallel Interface Data Synchronizer'DATA and Timing Generator'DISP_CLK ?
4.Let me confirm about IPUx_DI0_GENERAL register's discription.
  The discription includes following signal that like external pins.
  Are these pins internal signal?
  IPU_DI0_GENERAL bit22 IPP_PIN_2
  IPU_DI0_GENERAL bit21 External VSYNC
  IPU_DI0_GENERAL bit20 External CLOCK
  IPU_DI0_GENERAL bit17 Output Clock
  IPU_DI0_GENERAL bit7:0 di0_polarity_i_1
ko-hey
标记 (3)
916 次查看
igorpadykov
HI ko-hey
1. yes. For register settings of IPU one can look at SDK ldb example
2. yes understanding is correct and DI's output is connected to LDB input.
Connections can be found in Figure 39-1. LDB Block Diagram
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
also it may be useful to look at Figure 19-1. i.MX53 LVDS Display Bridge (LDB) Block
http://www.freescale.com/files/32bit/doc/user_guide/MX53UG.pdf
3. LVDS_TXx and LVDS_CLK are produced by LDB block internally, LDB uses
DI's output for its producing
4. all clocks described in IPUx_DI0_GENERAL are produced by IPU internally
for usage with LDB. For code examples one can look at SDK ldb example
i.MX6Q|i.MX 6Quad Processors|Quad Core|Freescale
917 次查看
igorpadykov
HI ko-hey
916 次查看
ko-hey
Hi Igor
Thanks!!
ko-hey
