How to enable log for fsl_imx_omx
958 次查看
lqll
Hi all
My environment is i.MX6Q and Android 4.4.2.
I want to check some errors when playing udp online video,so I have to enable all the log including low level log like debug info.As fsl_imx_omx has so many library,like ffmpeg,OpenMAXIL,etc,I think I need enable all the library log.Can u please tell me how to do this?
标签 (2)
1 回复
858 次查看
diegoadrian
If you want to see the log. You only need to connect the DEBUG/UART USB cable to your computer, and open a serial window. This will show you all the Android log.
I hope this information can help you.
Diego.
