hi all
My environment is i.MX6Q and Android 4.4.2.
When I use Android videoView to play UDP online video(H264,4M bitrate),some frames(not very much frames but obvious can find) are mosaic/blur, but when I play the same video local at the sdcard/sata,it does not have this problem and it's fluency.
I am sure my cable network is ok,I checked ifconfig,there is no errors or dropped Rx packets.
I've been changed android/external/fsl_imx_omx/lib_ffmpeg/libavformat/udp.c
-#define UDP_TX_BUF_SIZE 32768
-#define UDP_MAX_PKT_SIZE 1048576
+#define UDP_TX_BUF_SIZE 4194304
+#define UDP_MAX_PKT_SIZE 4194304
but it's not working for me,so it's not buffer problem.
So,anybody know how to solve this problem,please tell me,thank you very much!
