Any body can help me?
I am following steps to connect to jtag with realview ICE which is mentioned document "Hardware Development Guide for i.MX 6Quad..Families of Applications Processors"
in chapter 6.4 NOTE say at page 71 "go to www.freescale.com to obtain your copy of the Freescale_iMX6 Q.rvs file." to define the JTAG chain for a Cortext-A9 based chip. but I can't find that file
where can I find that file?
Seungik Lee
Solved! Go to Solution.
I found the enclosed in my "…/My Documents\ARM\rvconfig\platformFiles".
Thanks Yuri.
that file you attached works fine. I steps up to target connection.
But I faced new stage, When I try to access register mentioned in the Guide. memory access error occurs like following..
"Error: 0x021d0102: Error Memory access caused precise abort.
Debug Precise Abort Registers : DFSR = 0x00000005, DFAR = 0x020E0220 from target : Cortex-A9_3."
Often it is needed to run an initialization script before i.MX registers access.
Please try proper script from the SDK (tools):
Can you tall me how to run script file on linux ? or realview debugger?
In the RealView Debugger : Menu Tools -> Include Commands from File
Now I can access to Memory..
When I hold console at u-boot then connect to target , now I can access to memory and run script.
thank you for your reply (so fast reply ^^)
