How to change the ENET REF_CLK driver strength on MIMXRT1176AVM8A?
The Ethernet controller work in RMII mode.
In RMII mode, ENET_CLK is used as the REF_CLK, which is a 50 MHz ± 50 ppm continuous reference
clock.
Hi @shafers ,
Pad drive strength is controlled by DSE field in PAD control register. You can refer to page 786~791 in RM.
Jing
Hi Jing,
Could you tell me the detail info of this topic, thanks.
Shafers
Hi @shafers ,
Detail of the drive strength can be found in datasheet. Search DSE is datasheet.
Jing
