hi all
My environment is i.MX6Q and Android 4.4.2.
When I use Android videoView to play UDP online video(H264,4M bitrate),some frames(not very much frames but obvious can find) are mosaic/blur, but when I play the same video local at the sdcard/sata,it does not have this problem and it's fluency.
I am sure my cable network is ok,I checked ifconfig,there is no errors or dropped Rx packets.
I've been changed android/external/fsl_imx_omx/lib_ffmpeg/libavformat/udp.c
-#define UDP_TX_BUF_SIZE 32768
-#define UDP_MAX_PKT_SIZE 1048576+#define UDP_TX_BUF_SIZE 4194304
+#define UDP_MAX_PKT_SIZE 4194304
but it's not working for me,so it's not buffer problem.
So,anybody know how to solve this problem,please tell me,thank you very much!
Hello
Unfortunately, we cannot help you with your problem. Our support does not contemplate something related with the Android application development. I apologize for this inconvenient.
Diego
