How to add & build existing driver from imx source tree to kernel?
已解决
跳至解决方案
3,361 次查看
autoamp
We are planning to interface RPi 5MP camera with our custom iMX8M-Mini board.
Now RPi camera has OV5647 sensor, for which drivers are already available on iMX-own kernal source tree.
We are using yocto-project to build and configure images. Is there any step-by-step guide available that we can follow so we can integrate this driver in kernel-module?
1 解答
3,333 次查看
autoamp
Editing kernel .config worked for me.
to be more specific, inside your yocto build dir run.
bitbake linux-imx -c menuconfig
 https://www.yoctoproject.org/docs/1.6.1/kernel-dev/kernel-dev.html#changing-the-configuration
在原帖中查看解决方案
4 回复数
3,334 次查看
autoamp
3,352 次查看
joanxie
I send the ov5647 demo source code to you by mail, pls find it
2,801 次查看
BobCastlePeak
joanxie,
I would like to get the ov5647 working on the imx8m plus evk.  do you have demo source code you can share?
3,348 次查看
autoamp
Hi joanxie,
Thanks.. This should help..
