Does the ""Endpoint Conflict Issue in Device Mode"" occur with the i.MX 8M Nano?
Hi, thank you your reply.
How can I find the document with the silicon errata for the i.MX 8M Nano1?
Could you let me know the documents URL?
I found the following documents, which did not documented this issue.
https://www.nxp.jp/docs/en/errata/IMX8MN_0N14Y.pdf
imx8mn has the same USB IP as I.MX8MM and you can find the ERR050101
https://www.nxp.com.cn/docs/en/errata/IMX8MM_0N87W.pdf
