Does imx28 support networking in U-Boot?
618 次查看
drb55
Used (wasted) four days trying to enable networking (i.e., use DHCP) with U-Boot on my i.MX28EVK Board and then I found this update v2022.04 on github
uboot-imx/board/freescale/mx28evk at lf_v2022.04 · nxp-imx/uboot-imx · GitHub
mx28evk: Convert to driver model.
Make the conversion to driver model as it is mandatory.
Successfully tested booting Linux from the SD card.
Dropped support for networking and splash screen as these need to be properly converted to DM and tested.
If networking with U-Boot is not supported on imx28evk, how do I download code to the NAND flash?
Dan
标记 (3)
601 次查看
Bio_TICFSL
The network is disable for MX28, and the linux BSP is out of support since 2.6.35 kernel, if you are playing with the community bsp please go with them for support.
