Display Touch input not mapped properly with primary display
4,459件の閲覧回数
adithysm65
We are attempting to set up two displays and enable touch on the primary display for the i.MX 8 QuadMax MEK CPU Board using an LVDS to HDMI Adapter Card. We are using a USB Type-C connector (J17) for the touch input.
Here are the observations we have made:
The input is recognized but is not getting mapped when we connect the touch input to the primary display. However, when we connect it to the secondary display, the touch input works perfectly.
As a workaround, we interchanged the display ports, i.e., primary to secondary and vice versa. The secondary screen then takes up the resolution of the primary screen, which is not ideal for our project.
Following are the responses and logs received.
  • $ adb shell dumpsys SurfaceFlinger --display-id
    • Display 4632668096568543232 (HWC display 0): port=0 pnpId=RTK displayName="WaveShare"[15.6]
    • Display 4624778001127622657 (HWC display 1): port=1 pnpId=KTC displayName="WaveShare"[12.3]
      • [Touch input to primary display]
        • $ adb shell getevent -i | grep location
        • adb shell getevent -i
add device 1: /dev/input/event0
  bus:      0019
  vendor    0000
  product   0000
  version   0000
  version:  1.0.1
  events:
    KEY (0001): 0074
  input props:
    <none>
[Touch input to secondary display]
  • $adb shell getevent -i | grep location
add device 1: /dev/input/event1
  bus:      0003
  vendor    0712
  product   000a
  version   0111
  name:     "HID 0712:000a"
  version:  1.0.1
  events:
    KEY (0001): 014a
    ABS (0003): 0000  : value 0, min 0, max 1920, fuzz 0, flat 0, resolution 4
                0001  : value 0, min 0, max 720, fuzz 0, flat 0, resolution 2
                002f  : value 0, min 0, max 9, fuzz 0, flat 0, resolution 0
                0035  : value 0, min 0, max 1920, fuzz 0, flat 0, resolution 4
                0036  : value 0, min 0, max 720, fuzz 0, flat 0, resolution 2
                0039  : value 0, min 0, max 65535, fuzz 0, flat 0, resolution 0
    MSC (0004): 0005
  input props:
    INPUT_PROP_DIRECT
add device 2: /dev/input/event0
  bus:      0019
  vendor    0000
  product   0000
  version   0000
  version:  1.0.1
  events:
    KEY (0001): 0074
  input props:
    <none>
4,419件の閲覧回数
Zhiming_Liu
3 返答(返信)
928件の閲覧回数
harshi03
Could you please let me know which port on the board is connected to the touch input for the displays, and which port is being used for ADB access?
Please reply as soon as possible.
Thanks.
4,420件の閲覧回数
Zhiming_Liu
Hi @adithysm65
Have you tried to modify the input-port-associations.xml file in aosp?
https://github.com/nxp-imx-android/android-imx_device_fsl/blob/android-13.0.0_2.2.0/imx8q/mek_8q/inp...
4,412件の閲覧回数
adithysm65
Hello @Zhiming_Liu ,
Thanks for the solution,got the touch mapping right.
Just for someone with same blocker,
1)The 'input-port-associations.xml' is located under  /vendor/etc.
2)Check the input configuration of the display using the command $getevent -i | grep location.
3)Now change the configurations of the display mentioned under the xml file.
%3CLINGO-SUB%20id%3D%22lingo-sub-1837715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%82%BF%E3%83%83%E3%83%81%E5%85%A5%E5%8A%9B%E3%81%8C%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1837715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%80%81LVDS%E3%81%8B%E3%82%89HDMI%E3%81%B8%E3%81%AE%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%80%81i.MX%208%20QuadMax%20MEK%20CPU%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A72%E5%8F%B0%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%BF%E3%83%83%E3%83%81%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%83%83%E3%83%81%E5%85%A5%E5%8A%9B%E3%81%AB%E3%81%AFUSB%20Type-C%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF(J17)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%80%81%E6%88%91%E3%80%85%E3%81%8C%E5%BE%97%E3%81%9F%E8%A6%B3%E5%AF%9F%E7%B5%90%E6%9E%9C%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%83%E3%83%81%E5%85%A5%E5%8A%9B%E3%82%92%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%85%A5%E5%8A%9B%E3%81%AF%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AE%E3%80%81%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%BF%E3%83%83%E3%83%81%E5%85%A5%E5%8A%9B%E3%81%AF%E5%AE%8C%E7%92%A7%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%85%A5%E3%82%8C%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A8%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E7%9B%B8%E4%BA%92%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AF%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A8%E5%90%8C%E3%81%98%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%81%9F%E3%82%81%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E7%90%86%E6%83%B3%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%80%81%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E5%BF%9C%E7%AD%94%E3%81%A8%E3%83%AD%E3%82%B0%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%24%20adb%20shell%20dumpsys%20SurfaceFlinger%20--display-id%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%204632668096568543232%20(HWC%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%200)%3A%20%E3%83%9D%E3%83%BC%E3%83%88%3D0%20pnpId%3DRTK%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E5%90%8D%3D%22WaveShare%22%5B15.6%5D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%204624778001127622657%20(HWC%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%201)%3A%20%E3%83%9D%E3%83%BC%E3%83%88%3D1%20pnpId%3DKTC%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E5%90%8D%3D%22WaveShare%22%5B12.3%5D%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CU%3E%3CSTRONG%3E%E3%80%90%E3%82%BF%E3%83%83%E3%83%81%E5%85%A5%E5%8A%9B%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%B8%E3%80%91%3C%2FSTRONG%3E%3C%2FU%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%24%20adb%20shell%20getevent%20-i%20%7C%20grep%20location%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%E5%A0%B4%E6%89%80%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3Eadb%20shell%20getevent%20-i%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B91%E3%82%92%E8%BF%BD%E5%8A%A0%3A%20%2Fdev%2Finput%2Fevent0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9%EF%BC%9A0019%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC0000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A3%BD%E5%93%810000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%90%8D%E5%89%8D%3A%20%22sc-powerkey%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A0%B4%E6%89%80%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eid%3A%20%22%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.0.1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%AD%E3%83%BC%EF%BC%880001%EF%BC%89%EF%BC%9A0074%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%85%A5%E5%8A%9B%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%E3%80%90%E3%82%BF%E3%83%83%E3%83%81%E5%85%A5%E5%8A%9B%E3%82%92%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%B8%E3%80%91%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3E%24adb%20shell%20getevent%20-i%20%7C%20grep%20location%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%E5%A0%B4%E6%89%80%3A%E3%80%8CUSB-XHCI-HCD.1.Auto-1%2Finput0%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E5%A0%B4%E6%89%80%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3Eadb%20shell%20getevent%20-i%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B91%E3%82%92%E8%BF%BD%E5%8A%A0%3A%20%2Fdev%2Finput%2Fevent1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9%EF%BC%9A0003%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC0712%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A3%BD%E5%93%81000a%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30111%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%90%8D%E5%89%8D%3A%20%22HID%200712%3A000a%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A0%B4%E6%89%80%3A%E3%80%8CUSB-XHCI-HCD.1.Auto-1%2Finput0%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eid%3A%20%22%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.0.1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%87%A1%E4%BE%8B%EF%BC%880001%EF%BC%89%EF%BC%9A014a%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EABS%20(0003)%3A%200000%20%3A%20%E5%80%A4%200%E3%80%81%E6%9C%80%E5%B0%8F%E5%80%A4%200%E3%80%81%E6%9C%80%E5%A4%A7%E5%80%A4%201920%E3%80%81%E3%83%95%E3%82%A1%E3%82%B8%E3%83%BC%200%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%200%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%204%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0001%20%3A%20%E5%80%A4%200%E3%80%81%E6%9C%80%E5%B0%8F%E5%80%A4%200%E3%80%81%E6%9C%80%E5%A4%A7%E5%80%A4%20720%E3%80%81%E3%83%95%E3%82%A1%E3%82%B8%E3%83%BC%200%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%200%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%202%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E002f%20%3A%20%E5%80%A4%200%E3%80%81%E6%9C%80%E5%B0%8F%E5%80%A4%200%E3%80%81%E6%9C%80%E5%A4%A7%E5%80%A4%209%E3%80%81%E3%83%95%E3%82%A1%E3%82%B8%E3%83%BC%200%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%200%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%200%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0035%20%3A%20%E5%80%A4%200%E3%80%81%E6%9C%80%E5%B0%8F%E5%80%A4%200%E3%80%81%E6%9C%80%E5%A4%A7%E5%80%A4%201920%E3%80%81%E3%83%95%E3%82%A1%E3%82%B8%E3%83%BC%200%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%200%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%204%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0036%20%3A%20%E5%80%A4%200%E3%80%81%E6%9C%80%E5%B0%8F%E5%80%A4%200%E3%80%81%E6%9C%80%E5%A4%A7%E5%80%A4%20720%E3%80%81%E3%83%95%E3%82%A1%E3%82%B8%E3%83%BC%200%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%200%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%202%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0039%20%3A%20%E5%80%A4%200%E3%80%81%E6%9C%80%E5%B0%8F%E5%80%A4%200%E3%80%81%E6%9C%80%E5%A4%A7%E5%80%A4%2065535%E3%80%81%E3%83%95%E3%82%A1%E3%82%B8%E3%83%BC%200%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%200%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%200%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMSC%20(0004)%3A%200005%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%85%A5%E5%8A%9B%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%85%A5%E5%8A%9B%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B92%E3%82%92%E8%BF%BD%E5%8A%A0%3A%20%2Fdev%2Finput%2Fevent0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%82%B9%EF%BC%9A0019%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC0000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A3%BD%E5%93%810000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%90%8D%E5%89%8D%3A%20%22sc-powerkey%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A0%B4%E6%89%80%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eid%3A%20%22%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.0.1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%AD%E3%83%BC%EF%BC%880001%EF%BC%89%EF%BC%9A0074%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%85%A5%E5%8A%9B%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Display%20Touch%20input%20not%20mapped%20properly%20with%20primary%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%E5%9F%BA%E6%9D%BF%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%82%BF%E3%83%83%E3%83%81%E5%85%A5%E5%8A%9B%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%A9%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8CADB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1838377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Display%20Touch%20input%20not%20mapped%20properly%20with%20primary%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1838377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%83%83%E3%83%81%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%90%8C%E3%81%98%E3%83%96%E3%83%AD%E3%83%83%E3%82%AB%E3%83%BC%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%3C%2FP%3E%3CP%3E1)%E3%80%8Cinput-port-associations.xml%E3%80%8D%E3%81%AF%2Fvendor%2Fetc%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2)%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%24getevent%20-i%20%7C%20grep%20location%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E5%85%A5%E5%8A%9B%E6%A7%8B%E6%88%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E3)%20%E6%AC%A1%E3%81%AB%E3%80%81XML%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1838355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Display%20Touch%20input%20not%20mapped%20properly%20with%20primary%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1838355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231625%22%20target%3D%22_blank%22%3E%40adithysm65%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EAOSP%E3%81%AEinput-port-associations.xml%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-android%2Fandroid-imx_device_fsl%2Fblob%2Fandroid-13.0.0_2.2.0%2Fimx8q%2Fmek_8q%2Finput-port-associations.xml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-android%2Fandroid-imx_device_fsl%2Fblob%2Fandroid-13.0.0_2.2.0%2Fimx8q%2Fmek_8q%2Finput-port-associations.xml%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
