Display Touch input not mapped properly with primary display
adithysm65
We are attempting to set up two displays and enable touch on the primary display for the i.MX 8 QuadMax MEK CPU Board using an LVDS to HDMI Adapter Card. We are using a USB Type-C connector (J17) for the touch input.
Here are the observations we have made:
The input is recognized but is not getting mapped when we connect the touch input to the primary display. However, when we connect it to the secondary display, the touch input works perfectly.
As a workaround, we interchanged the display ports, i.e., primary to secondary and vice versa. The secondary screen then takes up the resolution of the primary screen, which is not ideal for our project.
Following are the responses and logs received.
  • $ adb shell dumpsys SurfaceFlinger --display-id
    • Display 4632668096568543232 (HWC display 0): port=0 pnpId=RTK displayName="WaveShare"[15.6]
    • Display 4624778001127622657 (HWC display 1): port=1 pnpId=KTC displayName="WaveShare"[12.3]
      • [Touch input to primary display]
        • $ adb shell getevent -i | grep location
        • adb shell getevent -i
add device 1: /dev/input/event0
  bus:      0019
  vendor    0000
  product   0000
  version   0000
  version:  1.0.1
  events:
    KEY (0001): 0074
  input props:
    <none>
[Touch input to secondary display]
  • $adb shell getevent -i | grep location
add device 1: /dev/input/event1
  bus:      0003
  vendor    0712
  product   000a
  version   0111
  name:     "HID 0712:000a"
  version:  1.0.1
  events:
    KEY (0001): 014a
    ABS (0003): 0000  : value 0, min 0, max 1920, fuzz 0, flat 0, resolution 4
                0001  : value 0, min 0, max 720, fuzz 0, flat 0, resolution 2
                002f  : value 0, min 0, max 9, fuzz 0, flat 0, resolution 0
                0035  : value 0, min 0, max 1920, fuzz 0, flat 0, resolution 4
                0036  : value 0, min 0, max 720, fuzz 0, flat 0, resolution 2
                0039  : value 0, min 0, max 65535, fuzz 0, flat 0, resolution 0
    MSC (0004): 0005
  input props:
    INPUT_PROP_DIRECT
add device 2: /dev/input/event0
  bus:      0019
  vendor    0000
  product   0000
  version   0000
  version:  1.0.1
  events:
    KEY (0001): 0074
  input props:
    <none>
Zhiming_Liu
harshi03
Could you please let me know which port on the board is connected to the touch input for the displays, and which port is being used for ADB access?
Please reply as soon as possible.
Thanks.
Zhiming_Liu
Hi @adithysm65
Have you tried to modify the input-port-associations.xml file in aosp?
https://github.com/nxp-imx-android/android-imx_device_fsl/blob/android-13.0.0_2.2.0/imx8q/mek_8q/inp...
adithysm65
Hello @Zhiming_Liu ,
Thanks for the solution,got the touch mapping right.
Just for someone with same blocker,
1)The 'input-port-associations.xml' is located under  /vendor/etc.
2)Check the input configuration of the display using the command $getevent -i | grep location.
3)Now change the configurations of the display mentioned under the xml file.
%3CLINGO-SUB%20id%3D%22lingo-sub-1837715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDisplay%20Touch%20input%20not%20mapped%20properly%20with%20primary%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1837715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3EWe%20are%20attempting%20to%20set%20up%20two%20displays%20and%20enable%20touch%20on%20the%20primary%20display%20for%20the%20i.MX%208%20QuadMax%20MEK%20CPU%20Board%20using%20an%20LVDS%20to%20HDMI%20Adapter%20Card.%20We%20are%20using%20a%20USB%20Type-C%20connector%20(J17)%20for%20the%20touch%20input.%3C%2FP%3E%3CP%3EHere%20are%20the%20observations%20we%20have%20made%3A%3C%2FP%3E%3CP%3EThe%20input%20is%20recognized%20but%20is%20not%20getting%20mapped%20when%20we%20connect%20the%20touch%20input%20to%20the%20primary%20display.%20However%2C%20when%20we%20connect%20it%20to%20the%20secondary%20display%2C%20the%20touch%20input%20works%20perfectly.%3C%2FP%3E%3CP%3EAs%20a%20workaround%2C%20we%20interchanged%20the%20display%20ports%2C%20i.e.%2C%20primary%20to%20secondary%20and%20vice%20versa.%20The%20secondary%20screen%20then%20takes%20up%20the%20resolution%20of%20the%20primary%20screen%2C%20which%20is%20not%20ideal%20for%20our%20project.%3C%2FP%3E%3CP%3EFollowing%20are%20the%20responses%20and%20logs%20received.%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%24%20adb%20shell%20dumpsys%20SurfaceFlinger%20--display-id%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3EDisplay%204632668096568543232%20(HWC%20display%200)%3A%20port%3D0%20pnpId%3DRTK%20displayName%3D%22WaveShare%22%5B15.6%5D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EDisplay%204624778001127622657%20(HWC%20display%201)%3A%20port%3D1%20pnpId%3DKTC%20displayName%3D%22WaveShare%22%5B12.3%5D%3C%2FSPAN%3E%20%26nbsp%3B%3CUL%3E%3CLI%3E%3CU%3E%3CSTRONG%3E%5BTouch%20input%20to%20primary%20display%5D%3C%2FSTRONG%3E%26nbsp%3B%3C%2FU%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%24%20adb%20shell%20getevent%20-i%20%7C%20grep%20location%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3Elocation%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3Eadb%20shell%20getevent%20-i%20%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3Eadd%20device%201%3A%20%2Fdev%2Finput%2Fevent0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20bus%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200019%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20vendor%26nbsp%3B%26nbsp%3B%26nbsp%3B%200000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20product%26nbsp%3B%26nbsp%3B%200000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20version%26nbsp%3B%26nbsp%3B%200000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20name%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22sc-powerkey%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20location%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20id%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20version%3A%26nbsp%3B%201.0.1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20events%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20KEY%20(0001)%3A%200074%20%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20input%20props%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%5BTouch%20input%20to%20secondary%20display%5D%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3E%24adb%20shell%20getevent%20-i%20%7C%20grep%20location%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%26nbsp%3B%20location%3A%20%22usb-xhci-hcd.1.auto-1%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%26nbsp%3B%20location%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3Eadb%20shell%20getevent%20-i%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3Eadd%20device%201%3A%20%2Fdev%2Finput%2Fevent1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20bus%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200003%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20vendor%26nbsp%3B%26nbsp%3B%26nbsp%3B%200712%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20product%26nbsp%3B%26nbsp%3B%20000a%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20version%26nbsp%3B%26nbsp%3B%200111%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20name%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22HID%200712%3A000a%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20location%3A%20%22usb-xhci-hcd.1.auto-1%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20id%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20version%3A%26nbsp%3B%201.0.1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20events%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20KEY%20(0001)%3A%20014a%20%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABS%20(0003)%3A%200000%26nbsp%3B%20%3A%20value%200%2C%20min%200%2C%20max%201920%2C%20fuzz%200%2C%20flat%200%2C%20resolution%204%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200001%26nbsp%3B%20%3A%20value%200%2C%20min%200%2C%20max%20720%2C%20fuzz%200%2C%20flat%200%2C%20resolution%202%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20002f%26nbsp%3B%20%3A%20value%200%2C%20min%200%2C%20max%209%2C%20fuzz%200%2C%20flat%200%2C%20resolution%200%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200035%26nbsp%3B%20%3A%20value%200%2C%20min%200%2C%20max%201920%2C%20fuzz%200%2C%20flat%200%2C%20resolution%204%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200036%26nbsp%3B%20%3A%20value%200%2C%20min%200%2C%20max%20720%2C%20fuzz%200%2C%20flat%200%2C%20resolution%202%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200039%26nbsp%3B%20%3A%20value%200%2C%20min%200%2C%20max%2065535%2C%20fuzz%200%2C%20flat%200%2C%20resolution%200%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MSC%20(0004)%3A%200005%20%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20input%20props%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20INPUT_PROP_DIRECT%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eadd%20device%202%3A%20%2Fdev%2Finput%2Fevent0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20bus%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200019%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20vendor%26nbsp%3B%26nbsp%3B%26nbsp%3B%200000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20product%26nbsp%3B%26nbsp%3B%200000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20version%26nbsp%3B%26nbsp%3B%200000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20name%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22sc-powerkey%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20location%3A%20%22imx-sc-pwrkey%2Finput0%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20id%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20version%3A%26nbsp%3B%201.0.1%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20events%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20KEY%20(0001)%3A%200074%20%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20input%20props%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Display%20Touch%20input%20not%20mapped%20properly%20with%20primary%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3EHi%2C%3CBR%20%2F%3ECould%20you%20please%20let%20me%20know%20which%20port%20on%20the%20board%20is%20connected%20to%20the%20touch%20input%20for%20the%20displays%2C%20and%20which%20port%20is%20being%20used%20for%20ADB%20access%3F%3C%2FP%3E%3CP%3EPlease%20reply%20as%20soon%20as%20possible.%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1838377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Display%20Touch%20input%20not%20mapped%20properly%20with%20primary%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1838377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%20%2C%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3EThanks%20for%20the%20solution%2Cgot%20the%20touch%20mapping%20right.%3CBR%20%2F%3E%3CBR%20%2F%3EJust%20for%20someone%20with%20same%20blocker%2C%3C%2FP%3E%3CP%3E1)The%20'input-port-associations.xml'%20is%20located%20under%26nbsp%3B%20%2Fvendor%2Fetc.%3CBR%20%2F%3E2)Check%20the%20input%20configuration%20of%20the%20display%20using%20the%20command%20%24getevent%20-i%20%7C%20grep%20location.%3CBR%20%2F%3E3)Now%20change%20the%20configurations%20of%20the%20display%20mentioned%20under%20the%20xml%20file.%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1838355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Display%20Touch%20input%20not%20mapped%20properly%20with%20primary%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1838355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231625%22%20target%3D%22_blank%22%3E%40adithysm65%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHave%20you%20tried%20to%20modify%20the%26nbsp%3Binput-port-associations.xml%20file%20in%20aosp%3F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-android%2Fandroid-imx_device_fsl%2Fblob%2Fandroid-13.0.0_2.2.0%2Fimx8q%2Fmek_8q%2Finput-port-associations.xml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-android%2Fandroid-imx_device_fsl%2Fblob%2Fandroid-13.0.0_2.2.0%2Fimx8q%2Fmek_8q%2Finput-port-associations.xml%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
