When we did the imx8mm test, we encountered the system warning that the temperature was too high, reaching 95 degrees, I would like to ask why there was a warning at 95 degrees when we were using an industrial grade chip and the theoretical temperature should be able to reach 105 degrees.
Can you share the kernel version?
Linux Kernel : L5.10.72
The temperatures are read from TMU on SOC, you can modify them with thermal sysfs.
echo 105000 > /sys/class/thermal/thermal_zone0/trip_point_1_temp
