Hi all
Let me confirm about the 24MHz Crystal Oscillator requirement for i.MX7.
I try to find some requirement in datasheet and reference manual but I can't.
On the other hand, some recommendations for other i.MX series are available in community etc,.
What data we need is "center frequency" , "Tolerance", "CL", "ESR" and "Max drive level".
Could you answer me whether those recommendation ca apply for i.MX7 or not ?
Please check following question.
1. For center frequency,
I found a following description in Section 4.8 XTAL Electrical Specifications of IMX53CEC.
Can it apply for i.MX7 ?
2.For Tolerance
I found a folllowing description in section 2.5. Oscillator tolerance of http://www.nxp.com/assets/documents/data/en/user-guides/IMX7DSHDG.pdf.
which tolerance value is your recommendation if user don't use above three interface ?
3. For CL & ESR:
I found following thread.
https://community.nxp.com/message/337037
4. For Max drive level
I found following description in table 1 of http://cache.nxp.com/assets/documents/data/en/engineering-bulletins/EB830.pdf?
Ko-hey
Solved! Go to Solution.
IMX7 Design Checklist does not mention about specific requirements
for 24 MHz XTAL ; generally, for assurance, You may follow i.MX6 ones,
which are more strict.
“Connect a fundamental-mode crystal between XTALI and XTALO. An 80 Ω typical
ESR crystal rated for a maximum drive level of 250 μW is acceptable.
Alternately, a 50 Ω typical ESR crystal rated for a maximum drive level of 200 μW
may be used. See the engineering bulletin EB830 for additional options”.
If Your applications do not provide any (real) timing requirements - there are no formal restrictions
for crystal stability. Nevertheless, the list of crystal parts, mentioned in 24 MHz Crystal Specifications ?
may be recommended.
Parameters of section 4.8 XTAL Electrical Specifications of IMX53CEC may be applied for i.MX7.
Yuri.
may be recommended.
Yuri.
