Can the IMX6Q output the LVDS video in only one pair Differential signal?
翔李
Hi, can the IMX6Q output the LVDS video in only one pair Differential signal?  Because the monitor which the IMX6Q board connects,has only one pari Differential signal interface. Thanks.
igorpadykov
Hi 翔 李
unfortunately not, this is fixed in hardware. From
IMX6DQRM Table 39-1. LDB - Block Description :
LDB has 2 channel serializers. The serializer does parallel to serial conversion 7:1 to
3 or 4 data lines
igorpadykov
Hi 翔 李
3 or 4 data lines
