Can't download images for iMX6ULEVK by MFG tool
1,341 次查看
joshzhao
I downloaded the imx6ulevk's packages(fsl-yocto-L3.14.38_6ul-ga.tar, L3.14.38_6ul-ga_mfg-tools.tar) from freescale website,  following the document to do it, the mfg tool shows that loading uboot,loading kernel,loading initramfs,Jump to OS image, then  No Device Conneced. It will reboot to do previsous steps again.   I make sure that all files is up to date and SW601, SW601 are right.
josh
标签 (2)
895 次查看
joshzhao
Hi Phani,
I am a newcomer of imx6ul too, but in my experence, u-boot maybe satify your requriement.
895 次查看
Hi josh
for mfg tools usage one needs to use *.vbs files to select
correct input data ("profile"), provided by cfg.ini file. Also use correctly peripherals
as described in i.MX 6UltraLite EVK Board Hardware User’s Guide
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6ULEVKHUG.pdf
895 次查看
phanikumar
Hi josh,
I am working on IMX6UL-EVK board. I want to run bare metal project (which does not involve any OS). Do you know how to run a helloworld project on bare metal. Could you please suggest any development tool? Do I need any extra hardware for debugging.
Thanks in advance.
