Hi Team
We made our options to boot from SD card during internal Boot, Can you please confirm when clock should come.Does it samples CD pin , then clock will come after ensuring SD card is there or something else ? What is sequence of whole process?.
How handshaking happen between SD card and processor ?
Hi Abhishek
sd boot sequence is described in Figure 8-10. Expansion device boot flow,
sect.8.5.3.4 IOMUX configuration for SD/MMC
i.MX 6Solo/6DualLite Applications Processor Reference Manual
>Does it samples CD pin , then clock will come after ensuring SD card ..
right.
