what is the difference between bitbake -c compile -f linu-imx and bitbake linu-imx
whenI run bitbake -c compile -f linu-imx this command it executed succesfully but when I try to do bitbake linu-imx it fails
解決済! 解決策の投稿を見る。
Please look at the following
Yuri
I tried to run core-image-minimal and it is running 3.14.28 version instead if 3.14.38...the 3.14.28 does not support for 3.14.38
Yuri
Thank you YuriMuhin_ng got the difference...
one more issue is when I do bitbake fsl-image-gui the .sdcard image is showing 880MB size. How can I reduce the rootfs. where as my zImage is 4MB only.
the .sdcard image includes U-boot, kernel and file system.
It requires to remove non-needed packages in order to reduce file system.
Perhaps it would be better to use core-image-minimal configuration.
Yuri.
