Android Oreo 8.0: Use two displays with different resolution
1,803 次查看
jdepedro
I am using the default images on the i.MX6 reference board and I see that when using HDMI + LVDS display, Android works in mirror mode showing the same content in both displays, rescaling it if needed.
How can I configure Android so that different resolutions are used? (The HDMI negociated resolution for HDMI, and the LVDS native resolution for the LVDS display)
1 回复
1,685 次查看
joanxie
you can boot up dual display successfully, but couldn't show the different resolution, right? pls refer to the topic as below:
https://community.nxp.com/thread/384600
