About current consumption
okamotosatoshi
Hello.
I want to check about i.MX6Q.
There is not a mention of the current consumption of each power supply.
(The power group described below.)
Could you tell me the maximam current consumption of each power ?
(In order to examine whether a VDDHIGH_CAP power supply can be used.)
・NVCC_ENET
・NVCC_LVDS2P5
・NVCC_RGMII
If you want to change in the use pin number of groups , please tell me the calculation formula.
-okamoto
Tags (3)
okamotosatoshi
Hi, Jorge
Thank you for reply.
Thank you for information.
Try to consider.
-okamoto
okamotosatoshi
Hi, Jorge
Try to consider.
-okamoto
JorgeRama_rezRi
Hi Okamoto,
The current consumption of each power supply depends on the use case and what operations is each block of the processor performing at a specific time. Do you know AN4509? It's about current measurements in different use cases. It has a max power use case I think will be useful for you. You can also find more info in section 4.1.5 of the MX6QD datasheet.
http://cache.freescale.com/files/32bit/doc/app_note/AN4509.pdf?&Parent_nodeId=&Parent_pageType=
Best regards.
Jorge.
