Dear NXP support,
I have a Logitech C920 (1080p@30FPS) camera that doesn't reach more than 5fps on the QM board running the following gstreamer pipeline:
gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-raw,width=1920,height=1080 ! videoconvert ! waylandsink
is there any know issue ? is there any chance to get it tested on your side ?
thanks for the support.
Andre
Solved! Go to Solution.
@AndreSilva
Please try using buffers in the pipeline (num-buffers)
Also customers can use so called zero-copy piplining,
described in Chapter 14 (Zero-copy Pipelines) of
the i.MX8 Gstreamer User Guide.
Yuri.
Thanks Yuri, turned out that the logitech cam for x-raw is only 5fps, I need to use x-h264 to get 30 fps, but then my output is completely wrong. I will check for correct pipelines with h264.
thanks,
Andre
@AndreSilva
Yuri.
