i.Mx6 CSI Test Mode Question
The customer would like to test BT.656 using Test mode. Is it supported?
  1. 38.4.3.3 Test mode in RM shows only one CSIx_SENS_CONG setting. Does it mean Test mode support only one as follows?
Does Test mode support other settings?
CSIx_EXT_VSYNC = 0x1
CSIx_DATA_WIDTH = 0x1
CSIx_SENS_DATA_FORMAT = 0x0
CSIx_PACK_TIGHT = 0x0
CSIx_SENS_PRTCL = 0x1
CSIx_SENS_PIX_CLK_POL = 0x1
CSIx_DATA_POL = 0x0
CSIx_HSYNC_POL = 0x0
CSIx_VSYNC_POL = 0x0
For example,
customer want to know if Test mode support  CSIx_SENS_PRTCL=0x2or 0x3 instead of 0x1?
customer want to know if Test mode support CSIx_SENS_DATA_FORMAT=0x1or 0x2 instead of 0x0?
Answer:
CSI CM TEST MODE is working as below:
1,only ungated mode.
2,data width should be configured to 8
3,data format should be configured to rgb888
It cannot be other format such as bt656. It uses CSI1_TST_CTRL register to configure {R,G,B} 24 bit value and taking it as RGB888/YUV444 format for further process.  The generated image size is due to the configured width & height in the registers.
Labels (4)
Tags (3)
%3CLINGO-SUB%20id%3D%22lingo-sub-1101222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.Mx6%20CSI%20Test%20Mode%20Question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20customer%20would%20like%20to%20test%20BT.656%20using%20Test%20mode.%20Is%20it%20supported%3F%20%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E38.4.3.3%20Test%20mode%20in%20RM%20shows%20only%20one%20CSIx_SENS_CONG%20setting.%20Does%20it%20mean%20Test%20mode%20support%20only%20one%20as%20follows%3F%20%3C%2FLI%3E%3C%2FOL%3E%3CP%3EDoes%20Test%20mode%20support%20other%20settings%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECSIx_EXT_VSYNC%20%3D%200x1%20%3C%2FP%3E%3CP%3ECSIx_DATA_WIDTH%20%3D%200x1%20%3C%2FP%3E%3CP%3ECSIx_SENS_DATA_FORMAT%20%3D%200x0%20%3C%2FP%3E%3CP%3ECSIx_PACK_TIGHT%20%3D%200x0%20%3C%2FP%3E%3CP%3ECSIx_SENS_PRTCL%20%3D%200x1%20%3C%2FP%3E%3CP%3ECSIx_SENS_PIX_CLK_POL%20%3D%200x1%20%3C%2FP%3E%3CP%3ECSIx_DATA_POL%20%3D%200x0%20%3C%2FP%3E%3CP%3ECSIx_HSYNC_POL%20%3D%200x0%20%3C%2FP%3E%3CP%3ECSIx_VSYNC_POL%20%3D%200x0%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFor%20example%2C%20%3C%2FP%3E%3CP%3Ecustomer%20want%20to%20know%20if%20Test%20mode%20support%26nbsp%3B%20CSIx_SENS_PRTCL%3D0x2or%200x3%20instead%20of%200x1%3F%20%3C%2FP%3E%3CP%3Ecustomer%20want%20to%20know%20if%20Test%20mode%20support%20CSIx_SENS_DATA_FORMAT%3D0x1or%200x2%20instead%20of%200x0%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EAnswer%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3ECSI%20CM%20TEST%20MODE%20is%20working%20as%20below%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1%2Conly%20ungated%20mode.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2%2Cdata%20width%20should%20be%20configured%20to%208%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3%2Cdata%20format%20should%20be%20configured%20to%20rgb888%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3EIt%20cannot%20be%20other%20format%20such%20as%20bt656.%20It%20uses%20CSI1_TST_CTRL%20register%20to%20configure%20%7BR%2CG%2CB%7D%2024%20bit%20value%20and%20taking%20it%20as%20RGB888%2FYUV444%20format%20for%20further%20process.%26nbsp%3B%20The%20generated%20image%20size%20is%20due%20to%20the%20configured%20width%20%26amp%3B%20height%20in%20the%20registers.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1101222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎06-06-2013 02:14 AM
Updated by:
