Hi All,
I am trying to get some of the Thread code examples working with my USB-KW24D512. I am using IAR & Windows 7. The projects build fine, but when I go to download to the target the compiler brings up the dialog show in the screenshot below. What additional steps are needed to get this to work?
Solved! Go to Solution.
Hi Sean,
You have to use external debugger such as JLink and P&E's Multilinks(Universal and Universal FX).
Cheers,
Antonio
Hi Sen,
Not the first time.
Please have a look at the below link for the USB MSD Bootloader:
https://community.nxp.com/docs/DOC-102539
Cheers,
Antonio
Hi Sean,
Cheers,
Antonio
I see. There is absolutely no way to flash the device over USB?
