WM828CC6: Not able to set channel for 5 GHz band
kinjalGediya
We are using the WM828CC6 module which is containing the Marvell/NXP 8887 WiFi chipset with i.MX8MQ platform.
we are using uaputl utility for setting wifi in AP mode and mlanutl or wpa_supplicant for setting station mode.
we are trying to set below channels as define in below table but we are unable to do that.
please find below commands which we are using for different mode.
please guide us for setting below channels for Wi-Fi.
FCC- 5GHz Band CE ETSI- 5GHz Band
Mode Channel "Frequency(MHz)"
n_40      38             5190
              46             5230
              151           5755
              159           5795
ac_40     38            5190
               46            5230
              151           5755
              159           5795
ac_80     42            5210
              155            5775
Tags (3)
