Solved! Go to Solution.
If you are using 88W8997, the driver will get the values from the 8997 structure, not 8897 nor 9098.
For instance, when using 88W8997 driver and fw from tag lf-6.6.3_1.0.0, the following structure will be used.
SD8997 = {
cfg80211_wext=0xf
sta_name=wlan
uap_name=wlan
wfd_name=p2p
max_vir_bss=1
cal_data_cfg=none
ps_mode=1
auto_ds=1
host_mlme=1
fw_name=sdiouart8997_combo_v4.bin
This means you can modify or even delete all the structures that are not for 88W8997, because they won't affect.
Daniel.
There was a typo in the question text.
The device I am trying to move is 88W9098, not 88W8997.
I was able to resolve the uncertainty while running the actual device, so I will close my question. Thank you for your response.
SD8997 = {
cfg80211_wext=0xf
sta_name=wlan
uap_name=wlan
wfd_name=p2p
max_vir_bss=1
cal_data_cfg=none
ps_mode=1
auto_ds=1
host_mlme=1
Daniel.
