Out Of Band Commissioning in Thread FRDM KW41Z
1,628件の閲覧回数
kunalkotecha1
Senior Contributor II
Hi All,
I want to use Out of Band Commissioning for NXP's Thread based FRDM KW41Z. I have followed the application guide and able to use the hybrid example (BLE + REED) as OOB method.
Currently, I am using the only master-key for OOB method. However, I would also like to use xpanID and network name for making the process more secure.
I went through the code and found "APP_OutOfBandSelectNwkWithBeaconCb" API for user to write required logic for the same. But, I don't know how to use this API and register the same to be called by thread stack.
Can anyone please help me on how to add xpanID and network key for OOB??
FRDM version:
a) BLE HOST v1.2.6
b) IEEE 802.15.4 MAC v5.3.6
c) NXP Thread v1.1.1.20
d) CONNECTIVITY FRAMEWORK v5.3.6
e) Thread SDK: SDK_2.2.0_FRDM-KW41Z_LINUX
Kunal
ラベル(2)
5 返答(返信)
1,406件の閲覧回数
estephania_mart
Could you please let me know which application note it's the one you are following and referring to?
Estephania
1,406件の閲覧回数
kunalkotecha1
I am referring to "Kinetis Thread Stack Application Developer's Guide.pdf", section "4.3.5.3 Out-of-band commissioning network selection callback".
I am only setting the master-key in hybrid end device application and then able to join the network. According to my understanding, to join the network using the OOB method, we need to give master-key, extended pan id, and network name. Can you help me with how to enable all these parameters in order to join the network with host??
Kunal
1,406件の閲覧回数
estephania_mart
I have been checking for a more detailed guide on how to achieve it and I believe this video makes just what you are trying to do
Kinetis KW41Z + Thread - Using Bluetooth Low Energy with Thread - Part 9 | NXP
Could you please check it and help me confirm?
Estephania
1,406件の閲覧回数
kunalkotecha1
Thanks for sharing the video. However, I am not looking for how to run BLE + Thread hybrid application. I want to use OOB commissioning. I want to make the method more secure by providing extended pan, master-key and network name, instead of only providing master-key.
Kunal
1,406件の閲覧回数
estephania_mart
In the same way, you are passing the master-key in the demo you will need to pass/limit the rest of the information you wish.
The only thing that you will need to consider it's that the thread application (cellphone app), might not work correctly as it won't know how to take that new information.
Estephania
