I want to modify the parameters in the following table. What are some ways to do that? I found "zps_gen.c" file is only read!
PRIVATE const zps_tsNwkNibInitialValues s_sNibInitialValues =
600,
05,
7,
15,
1,
2,
11,
18,
0,
2,
0,
1,
0,
15,
3,
3,
255,
5,
TRUE,
TRUE,
5,
4,
1,
2,
8
,0/* u16VerifyLinkCostTransmitRate */
Liqidong
Hi, Li
another way to change value inside zps_gen.c is modify corresponding item in zpscfg
You can modify the structure.
For example:
ZPS_tsNwkNib *psNib = ZPS_psAplZdoGetNib( );
psNib->sTbl.psNibDefault[0].u8MaxRouters = 0x01;
Mario
