How to configure LEDs in the MC-13226 board? Basically, the LEDs have to toggle based on commands from an external signal.
Hello Harish,
BeeKit application examples already contain a LED driver you could use for any purpose. The file location depends in the codebase used, for instance:
This driver contains functions such as LED_TurnOnLed (),LED_ToggleLed(), etc. I am pretty sure you will find it very useful for your application.
AngelC
You can do follow the example
external signal is key4
In "BeeApp.c" file you find "BeeAppHandleKeys void function (key_event_t events)"
You modify
gKBD_EventSW4_c case:
break;
into
SetOneLed (LED4, gLedToggle_c);
break;
When the program starts, you press key 4, then Led 4 will toggle.
The Functions of LEDs you can find and modify in folder
PLM->Source->Led->Led.c
Hope this example will help you.
