When JTAG is used to debug JN5169, a DEBUG will give the following tips. What is the reason? JTAG tools adopt ST-LINK V2,Thank you!
Error with command: ba-elf-gdb.exe --version
Cannot run program "ba-elf-gdb.exe": Launching failed
Hi Anjy,
Did you install the JN-SW-4165 SDK? The debugger is looking for exe files that are included in this SDK.
Please look at the JN516x JTAG Debugging in BeyondStudio
Mario
