I am trying to create the firmware code of KW24D512USB_Sinffer.srec using beeKit application. Can you please let me know which codebase i need to use or which sample project I need to start with?
Thank you!
Solved! Go to Solution.
As I know, beekit application didn't provide sniffer project code. You could load "KW24D512USB_Sinffer.srec " into your KW24D512 USB board directly. Please let me know if you have no idea where to find KW24D512USB_Sniffer.srec file.
Thanks for the reply. I know where to find the .srec file but i want to know how to create the firmware code using the beekit. Thanks!
