I'd like to submit some voltage and power data.It's the Power Configuration Cluster?How to use Power Configuration Cluster? Thanks!
Are you sure you followed the complete steps mentioned in this guides?
https://community.nxp.com/docs/DOC-335075
https://community.nxp.com/docs/DOC-333994
Estephania
But which problem are you having? Do you have some logs? Is your problem regarding the value gotten or is it when reporting? Could you please provide more details?
Estephania
And did you add and configure the attributes correctly as stated in the B.2 Configuring Attribute Reporting?
Estephania
