Hi ,
We are working with NXP (JN5189) as co-ordinator and pairing multiple zigbee sensors.
Test Setup
Attached log with MAC Address (0XA789) details. Sensor is sending ROUTE request instead of IAS ZONE change notification. Why is sensor not able to find route ?
In which cases will this scenario occur?
Sorry for the inconvenience this might cause you, but as this product has not been released yet, the support should be done through the resources that helped you getting the device. and the information of it.
Estephania
