If firmware changes are necessary, can you provide insight into the quantity and scope? I was able to integrate the LPCD sample code into my application with little modification. For example, I did not need to adjust any firmware-controlled antenna tuning parameters with the CLRC66303
Thank you
MFRC63003 can replace it depending on your application. Please find more information as the link.
URL:https://www.nxp.com/docs/en/data-sheet/MFRC630.pdf.
Have a nice day.
