It seems that the BR node and BR host do not communicate with each other.In fact,the node receives periodically a reset signal from the watchdog since it does not receive the configuration from the host , it loops in the following while statement (in the AppColdStart fonction) :
while((!sFlags.bRunCoordinator) && (!sFlags.bRunRouter))
/* See if there is any data available on the serial link */
vProcessDataFromLink();
P.S.
I used Raspberry Pi B with the OpenWRT from JN-AN-1110.
Hi Aicha,
I will take a look, I will answer as soon as possible.
Best Regards
Mario
Hi Mario,
Thank you for getting back to me.
I look forward to your response :smileyhappy:
Hi Aicha,
I'm sorry for the late answer. I'm still checking this issue.
Did you follow the steps mentioned in the next User Guide for a simple test?
http://www.nxp.com/documents/user_manual/JN-UG-3093.pdf?fsrch=1&sr=1&pageNum=1
Please let me know your findings,
Best Regards
Mario
Hi Mario,
I followed the instructions of JN-AN-1110 since I am not using the Linksys Router of the evaluation kit.
Unfortunately,the issue haven't been resolved.I am still working on it.
Please let me know if you will find an answer .Thank you!
Hi Aicha,
Did you get resolution yet?
Thanks!
Bill Krakar
Unfortuantely not . I am still waiting for the team to respond .
Thank you for your consideration !
Hi Aicha,
I will ask the dispatcher to help with this.
Bill Krakar
Hi William,
Are there any news concerning my issue?
Thank you!
Hi Aicha,
I will ask dispatch to review your request.
Bill Krakar
