In AN12380 Application Note is mentionned that we can download a zip file where there is a matching circuit clculation excel sheet. Where can I find this Zip.File ?
Solved! Go to Solution.
Hi @danielchen ,
I have another question to one of the attachement in AN12342
One of the DXF attached files should be for a rectangular coil. But both files are for a circular coil. Where can I find the file for the rectangular shaped aMifare Card.
Thanks in advance.
I will attached it here if I get it.
Thank you
Hi @amighri :
I sent the DXF drawing file to your email address. Next, we will update the Application note. Thank you for reporting this issue.
