I have a development board of FRDM-KW019032. I use it to program a TPMS sensor that its MCU is FXTH87xx11. But the yield rate of programming seems no good. I use 125KHz to send the programming data to TPMS sensor. I want to know how to adjust the 125KHz TX antenna to make a good programming yield rate. Can anyone guide me?
Hi Ted,
Improving LF reception can be done by:
I hope it helps!
Tomas
